trapezeartist
I have a leak from my domestic water system into the bilge. After a bit of poking around I traced it to the hot outlet from the calorifier. It's the plastic fitting going into brass.
Can anyone explain to me how these fittings come apart? All the other similar fittings seem to have a bit of axial free-play on them but the leaking one is rigid. Perhaps because it has never been pushed home properly?
Each fitting has a white plastic ring which rotates but doesn't do much else. I fancy that might be something to do with releasing the connector though.
