Push Pit Mountings
maxi77
11 Nov 2007
Kingdom of Fife
I am looking for some form of stainless steel clip/clamp to secure a vertical mast to the horizontal part of the push pit rail. I have tried the usual suspects such as PICEA and Seasure with no luc. Any other suggestions welcome.
Thanks all.
i have recently used jubilee superclamps for this very purpose. replace the securing bolts with a threaded rod cut to size, face the clamps in opposite directions with the threaded barrels to the outside, thread the rod in from one side, once thru` the first clamp put 4 nuts on and screw it thru`to the second clamp. once you have it set up close the clamps up with the 2 outer central nuts and use the inner 2 as lock nuts.
Plastimo do a strong black platic block for 1 inch rails. We recently bolted two of these back to back to solve this problem and mount a verticle pole for AIS and nav light. Came from the local chandlers, about £7 I think.
