Lomax
Hi all,
I'd like to fit a push button solenoid to reduce the current required to trigger the starter motor (~30A), while also allowing me to run the starter from the engine bay. The ignition signal source (a VDO Logic Combi instrument) can only deliver a maximum of 1A, which really isn't a lot. I've been looking at the Lucas SRB316/319 equivalents (e.g. Cargo 233955, Durite 0-335-05), but while this is a neat all mechanical solution I cannot find any information for the activation current - if it's more than 1A (which seems likely) this is not going to be a good fit, as it would necessitate an additional relay or solid state switch in the chain. I could fit a beefy DC relay instead of the solenoid and add an electrical push button next to it, but I'm curious how others have solved this?
Cheers!
Cheers!
