purpose of baby stay?
Ardenfour
7 Feb 2004
Port Bannatyne
My recently acquired boat came with what was deswcribed as a 'quick-release' baby stay. A full-thickness wire stay attached with a snap shackle and rigging with a fold-out handle, to tension/detension the stay. Runs from a deck u-bolt about 5ft in front of the mast up to the spreaders. The p & s lowers are in line with the shrouds, so any decent tension on the baby induces a mast bend. It's a masthead rig. I thought the idea with a masthead rig was to keep the stick straight at all costs - a bend simply meant that the forestay would not tighten, but would increase the bend? Tacking would be a lot smoother without the baby to foul the genoa, so what's it for? and can I move it out the way under some conditions?
More details of your rig required. You have the P&S lowers inline with the caps? ...... does that mean you have aft swept spreaders with the cap shrouds going aft of the mast or are they all in line with the mast
Normally forward lowers counteract the pull of the main sail and if the mast is bendy are usually set to induce some prebend. A baby stay can do this in their place but of you have aft swept spreaders the tension in the caps does much the same.
If you pull the centre of the mast forward, the top can actually goes aft a little, and if it does, the forestay will be tightened... bending the mast will also flatten the main depowering it a little... far from a straight mast being essential, managing mast shape is a useful skill in getting the boat to work well, and can help manage power and balance.
Sometimes also, a detachable babystay is to stop the mast pumping as much as changing the mast's shape.
EDIT - if its detachable, presumably the rig is set up to be secure without it, and the stay is there mainly to provide an extra control to mast shape, and extra support in extreme conditions, so should be fine under normal sailing without it.
No halyard associated with it - I wouldn't like to attach any sail to it, there seems to be nothing to stop the mast bending forwards in the middle as lowers are in line with caps...
detachable is to facilitate for dip pole gybing
VicS, the lowers are in line with the cap shrouds - go to the same chainplate
And they are in line with the mast or aft of it... difficult to be sure from the photo. In line from waht you say above in #8 ?
VicS yes, lowers are inline. This (poorer) picture shows the lowers and caps on same plate. The reason the spreaders appear swept back slightly is due to the baby stay bending the mast.
