Clyde_Wanderer
I have been advised not to use PTFE tape on s/s to s/s through hull fittings, namely on the threaded part of a s/s through hull where it will be screwed into the s/s ball valve. (both parallel threads)
Was adviced to use Sikaflex or similar, but I am worried that the valve would turn in the event of being opened or closed due to length of its handle.
Whereas with ptfe tape the valve can be horsed up tight on the t h.
What does the board think?
C_W
C_W
