julianmingham
Hi all
I've got a persistent PRV blow-off issue that I'd like to get forumites input on.
Here's the background:
Boat is a Westerly Oceanlord
Pressurised fresh water pump is a Flojet R4405-143 rated at a flow of 12.5 LPM and a cut-out pressure of 35 PSI
There is an expansion tank fitted, CW269 from Cleghorn Waring
The PRV on the calorifier is rated at 3 bar (which is 43.5 PSI)
I am using a Halfords digital tyre pressure gauge to measure the air pressure at the expansion tank
I've been suffering from a PRV blow-off issue. The blow-off from the PRV is led to a plastic bottle in the bilge, and when the water in the calorifier was hot it would fill a 2 litre bottle in less than 24 hours. When the water in the calorifier is cold I do get some blow-off but at a much lower rate
I've so far taken the following steps:
1. I turned the knob on the PRV to make sure that it seats well, but that made no difference.
2. I replaced the PRV on the assumption that it was faulty. That did make a difference, i.e. the discharge into the bilge was reduced, but it was still discharging albeit at a slightly lower rate.
3. I replaced the expansion tank, as further investigation discovered that the tank was not maintaining air pressure. I set the air pressure according to the instructions from Cleghorn Waring, i.e. 2 psi below the cut-out pressure of the tank (so I set it to 33psi). Sadly this made no difference to the discharge into the bilge.
4. I measured the air pressure at the expansion tank with the fresh water pump switched on and the water in the calorifier cold. I was surprised to find that it measured 41psi.
5. I switched the pump off, ran the tap to release the pressure, and released all of the air from the expansion tank.
6. I then pumped the expansion tank back up to 33psi
6. I switched the pump back on and measured the air pressure at the expansion tank - it was 42psi
I'm now wondering what to do next, ...
I'm assuming that the measurement at the expansion tank with the pump switched on is actually the cut-out pressure of the pump ? If that is the case then it shouldn't be 42psi.
I'm starting to think that I need to change the fresh water pump, but not sure whether to change it for another one the same spec. or to go for a lower pressure in order to increase the difference between the cut-out pressure of the pump and the pressure that the PRV will start to lift at ?
Can someone advise please ? Thanks
