Nicholas123
N/A
Oh dear.
What's that supposed to mean? If smearing with Vaseline protects from air while at the same time showing continuity what more could you want!
Oh dear.
Best thing is to start out with decent materials in the first place, tinned cable and tinned copper terminals instead of the nasty pre packs from chandlers and Halfrauds et. al., don't use spades where you can use ring terminals. For extreme exposure parts in anchor lockers and similar areas make sure the connections are bright, tight and free from grease then apply liquid neoprene, sometimes sold as liquid insulating tape. For less critical areas use protective grease, my favourite is Servisol which has been around ever since I can remember and gives good results. For well protected dry areas provided the materials used are of good quality there is no need for any protection other than that provided by the quality of the materials used. For things like relays which you have no control over terminal quality using the liquid neoprene is no bad thing wherever they are sited.
This makes interesting reading for those interested in the dialectric -v- conductive grease debate.
http://www.w8ji.com/dielectric_grease_vs_conductive_grease.htm
If smearing with Vaseline protects from air while at the same time showing continuity what more could you want!![]()
There is a lot more to continuity than testing with the continuity range on a meter. You would get a positive reading if a single atom was in contact. OK, I exaggerate, but it makes the point.
When there was nothing better, I also used Vaseline for this. Times change.... Vaseline is or was universally used for protecting the battery terminals ...
A friend of mine reckoned you could smear Vaseline around the battery terminals & then tighten them down & the pressure produced a good connexion which surprised me but then Vaseline is or was universally used for protecting the battery terminals so I'm afraid I still doubt your information Nigel.
The Juries still out as far as I'm concerned.
how do you test it when you can't stick a multi-meter on the terminals?
