Tranona
But what size gap should there be between the rope cutter and P bracket to allow water flow through the cutless?
Ideally 10mm. The cutter is 30mm thick so this gives an overall gap of 40mm. Typically the gap on an original installation without cutter can vary from less than 10mm up to 30mm or even more (on a 1" shaft). Retrofitting the cutter usually requires a spacer between the flanges on the gearbox and prop, which comes in 10mm increments so you can get close to ideal. If the gap is more than 40mm then the extra space is between the cutter and the prop to get the striker plate mounted in the ideal position on the P bracket. Sometimes an R&D flexible coupling which is 30mm thick can be used as a spacer.
