davidwf
Just discovered that my propshaft on a 5 month old boat has badly corroded under the rope stripper see picture below. Prop is OK. The Stripper is unmarked its just the shaft, I suspect I need to replace the shaft, any ideas what would have caused this? If it was electrolytic corrosion I would have thought the brass prop would have corroded first. I did note that there was no shaft anode on the shaft, although I was told one had been fitted so that might well have coroded and dropped off. Boat has a galvanic isolator and has only been on shore power for about a month.
