Avocet
Last weekend our 1.6 kW Propex eater died. Te fan was making "bearing" noises and then it seized and blew the fuse. I took it to bits, only to find that the bearings were fine, but the armature has been rubbing on the inside of the magnets. I don't quite know how this has happened. It hasn't been bashed or dropped. There's no discernible play in the bearings.
Does anyone know:
(a) if I can grind a bit off the armature without adversely affecting anything? (presumably the motor will go out of balance slightly)?
(b) if it's possible to get a replacement motor?
The motor markings seem to be unique to Propex. It says "Propex" on it and E-2819-420-009 and "N26 Canada".
Does anyone know:
