geem
Pretty well all of the smaller yacht engines transmit their thrust onto the gearbox and thus through to the mountings. This has never been a problem unless you have allowed diesel to leak over you mounts for years. (in which case you may get a horrible surprise in bad weather!)
I had a Victory 40 with a 75HP Perkins mounted on 4 level mounts. Behind that was a lorry propshaft with UV joints at each end. The propellor shaft itself ended (inboard) with a taper machined 6 inches from the end and a taper trust bearing attached to a substantial frame on the hull. The lorry propshaft was connected to a flange on the end of the propellor shaft. This meant that the engine - although sort of aligned, had a large tolerance to misalignment.
A little over engineered perhaps? Wonderful to have all that power on tap on a slow turning 3 blader. go any where vessel that was and fast once the wing had piped up.
We have a similar set up on a Trintella 44. The 2" s/s prop shaft terminates at the inboard end in a grooved slot that fits a tapered bush inside a thrust block. Lorry prop shaft makes the connection to the gearbox. A great design
