MYStargazer
Cheers, Paul.
Propeller aperture is 11½"
Back of a fag packet Crouch's method.
Crucial specs:
Hull type: semi-displacement
LWL: 30’ / 9.15m
Displacement = 8000 Kg
BHP = 2 x 180 @ 2,600 RPM
Gearbox = 1.52:1
You have the POTENTIAL to swing a wheel between 19 ½ to 18 ½ inches. Largest diameter is more efficient however will likely rumble, 18½ diameter will be sweet but I will live a little on the edge, so let’s plump for 19 inches.
Wind the handle the slide rule and out pops a 'square' 19X19 propeller giving 18.5 knots @ 2,600 rpm WOT and 16.5 knot cruise @ 2,400 rpm.
A slightly 'safer' 19X18½ will likely bring WOT speed down to 18 knots.
Give prop manufacturers the raw data and see what sexy programs come up with.
Good hunting.
Thanks, guys. I'm guessing the suppliers will carry out their own calculations to make sure they sell you the correct props.
I came across these guys Axiom Propellers (http://www.axiompropellers.com) - interesting looking design. Anyone got experience of these types of props? I'm at a loss as to why anyone would want "equal thrust in both ahead and astern" as claimed...
Fitzroy
Managed to get this sorted yet? If it helps, I have a Wey 32 running the original perkins HT6.354M engines (145 shp at 2400 rpm). She had new props a few years ago and is currently fitted with 4 blade 22" X 24". According to data that came from the previous owner she previously had 3 blade 22" x 23". Current props look enormous but engines nave no problem reaching max rpm so they can't be too big.
As to weight, not put mine on a load cell but suspect 8,000+ kg is going to be closer to the truth. Boats only get heavier with age!
Fitzroy
brunel made props not that different !
