boggybrn
I need to replace the cutlass bearing on my Newbridge Pioneer, but after several attempts haven't been able to get the propeller off.
I have tried a variety of 3 leg pullers, the last of which was a fairly substantial looking one from Halfords. With this tightened up I have tried bashing the puller screw with a lump hammer, and have heated the prop with a blow lamp. In the end I cracked one of the feet on the puller.
So... are there any other options?
The difficulties I have are:
a) There is only 5" from the end of the prop shaft to a skeg. (I had to shorten the screw for the puller to fit this gap)
b) The forward face of the propeller hub is quite rounded (presumably from previous removal, but slightly worse now.) So it is dificult to get the claws from a 3 leg puller to grip well.
I saw a sketch in a Don Casey book for a puller made from plate steel, with three bolts. This looks hopeful, but I need a source for suitably thick steel (maybe 8mm thick, 2 bits about 6" square). Failing this I'm close to trying to get someone else to do the job.
Any recommendations for either of the above in the Fareham / Portsmouth area?
