Propeller nut sealant
Jokani
21 May 2014
When I removed the propeller nut, it looks as though it has previously had gasket sealant of some type of adhesive to secure it:
Is this normal practice, and should I seal/glue it again when I replace it?
Its done to stop leakage on the flange face, but most forget to seal the other end. IMHO tis a bit of flannel and really serves no purpose, so don't worry about it.
I refitted my prop, castle nut and ss split pin. Before launch I had some epoxy left from installing the cutless so smeared it over the nut, pin and shaft threads on the basis that it was extra and could not any harm
I know there is nothing to be affected by water penetration but some of these "pro" marine engineers do this sot of thing, in fact I recently was asked to remove a nut that was tight and found that 601 retainer had been applied, asked who did the last refit "Oh so &so" and produced the bill.
On it stated "I thought the threads are worn and firmed up with a special sealed" item cost £2.50
It looked to me that the blue stuff in the OP photo is not on the threads, just the mating faces. I'm surprised it is there if the nut was tight, I would have expected it to extrude out.
It was definitely tight, it needed a v large spanner to remove, but I guess there must have still been some space between the two.
This may have been some gasket material to allow the hole in the prop shaft to align with the hole/castellation in the nut for the cotter (split) pin when it was torqued up.
That's a good point I was forgetting that I would need to align that hole again!
don't flog the nut up tight, firmly at first, keep tightening until a slit pin will enter, job done,
Main thing is to ensure that the nut is tight enough. If the gasket material was there to make up a gap it suggests that the nut was not tight enough before, my earlier point. I have recently had to replace the prop on my motorsailer because the nut was not tight enough, allowing the prop to move on the shaft. This resulted in a crack the full length of the boss, fortunately found before the whole prop fell off. This was immediately following a 150 mile voyage, so we were lucky!
A few years ago, I had a new propshaft made by T.Norris Ltd and it came without a hole for a split pin and with an ordinary nut. I was assured that modern locking compounds made split pins and castellated nuts uneccessary.
I wasn't convinced. What works when assembled in a nice clean workshop might not do so well when done in a hurry, dried out alongside a wall. Also these locking compounds aren't cheap, have a shelf life and aren't always readily available when you need them.
Anyway, I asked Norris's to drill a split pin hole and to supply a castellated nut supplied and that was done.
