RobbieW
On passage the other day in a quartering sea of about 1m with a period of 3-4 seconds we experienced something that felt as if the engine was being stalled. This happened perhaps a dozen times in about 6 hours until the sea subsided a little. As the boat rolled with a wave going under us, the engine note sounded as if it stopped for a second or so and then carried on - most disconcerting.
I'm trying to understand what was going on and what I should now be having a close look at. We have a Brunton Autoprop so one of the few theories I have is that the speed of the wave passing under was sufficient to try to reverse the prop blades and try to stall the engine - feasible?? The roll when this occurred was away from the exhaust so I dont think that back pressure was involved.
I will certainly be having a close look at the plastic drive coupling on the shaft and the engine mounts, I'll also have a feel of the prop blades next time I dive. Anything else ?
