Tranona
Ianj99 and Tranona interesting conversation. I can't really add a balanced opinion but I can add my observations from my own boat.
She has a Perkins 4236 with 1.91 : 1 gearbox reduction. I don't have my prop size at hand but it is a large diameter, quite large pitch and is 3 bladed.
The yacht was apparently set up for long distance cruising by a previous owner who selected the current arrangement to speed the boat along at low rpm. At about 1500 rpm she is doing 6 kts. At 1800 rpm she was doing about 7.5 kts but cavitating very loudly (1500 rpm is the sweet spot) with her stern well dug in. I also experienced having to motor into short 1 m chop, from a F7 and she still cut 6 kts at 1500 rpm.
I am not so sure what the maximum power rpms are for this engine but it will be around 2500 rpm.
I have since discovered that the original design had a 2 bladed prop and was not so pitched. At tick over I will get up to 3 kts so close quarters slow manoeuvring requires a lot of neutral to keep the speed down below 2 kts.
The big pitch on the current prop provides a lot of kick in reverse to the point of irritation. At slow speed bringing her to a stop still produces a lot of prop walk.
So I would tend to agree with Tranona that there is much more to be taken into account. I did a few searches on Googol when looking into re propping my own boat and there are lots of folks moaning about performance after changing propellors!
All the symptoms a prop that is too big - and maybe an engine that is too powerful for the boat.
If you can get the power curve to get the max HP (not what it says on the brochure), revs, waterline length and displacement you can get a good estimation of the optimum size from the Propcalc programme. Also useful to know the maximum diameter of prop you can swing.
