Prop Size advice
  • Start date Start date
G
Guest
Guest
I just fitted a new engine and the prop I chose with advise from the engine Manufacture and a prop calculator were both wrong! I need to get the right one does anyone know how I can ensure I choose the correct one? Engine is beta 28hp 2:1 gearbox and ona Westerly SeaHawk 34 ft LWL 28ft.. I have a 14X9 which is far to small, 2000 rpm gets me around 2.5Knts..
Hope someone can help me?
Shreck
<hr width=100% size=1>
G'day Ken.
If you deal with a prop manufacturer, they will swap a prop if it's not what you expected at no cost, having said that, they won't pay for haul out.
I have included some web sites for your information, are looking you looking at fixed, folding or feathering props?
http://www.autoprop.com/
http://www.yanmarhelp.com/Install/prop_clrcs.htm
<hr width=100% size=1>Andavagoodweekend, Old Salt Oz /forums/images/icons/cool.gif
Performance indicates something more fundamental than size. Not wishing to patronise but have you got the handing right? When I installed my Beta the hand changed relative to the previous Yanmar.
Umm, interesting Prop calc gives me around the size you've got fitted as well.
Not being stupid but it is the correct size isn't as I've just had a traumatic prop incident and the prop was no where near the marked size!
I guessed 6 ton, max revx 3,800. As someone else said it sounds fairly fundamental.
<hr width=100% size=1>Jim
Draco 2500
IMHO your prop is way undersized.
I had a 15*13 3 bladed prop fitted to my 34ft yacht (6.5 tons) using a Yanmar 3GM engine (21hp). The engine would push the boat at about 6 knots. Reverse was virtually none existent. (I suspect due to thickness of skeg obscuring large part of flow.) At max revs the engine was not struggling.
I changed this last year to a 17x14. This was way oversized with the engine only able to do 1500 revs but reverse was great.
I have just changed it again to a 16x13. This is much better. The engine is much smoother and whilst I still cannot obtain max revs reverse is still usable.
Your boat size and weight sound very similar to mine. You have more hp and consequently I suspect a 16 x 13 is probably closer the mark. (My gearbox ratio if I remember correctly is 2.36:1.)
Others may differ.
If you want to try a 17*14RH 3 blade prop with 1" shaft I can lend you one.
