Prop shafts dia
Enterprise6
Active Member
3 Mar 2011
Hi I have a Fairline Turbo 36 with tamd 40B. Does anybody know the property shafts diamond as I'd like to order some rope cutters.
Thanks in advance
They are probably 1.75 inch.
You should be able to put a vernier on the shaft in the engine room.
You need to think whether you need a spacer on the coupling to drop the prop and shaft back enough to fit the rope cutter.
What speed does she do with 40b engines in, is she used on the river?
