Floating Mechanic
New Member
Hello and good day fellows!
I remember coming across this info somewhere on the net, but it seems this disappeared along a lot of good info out there lately. So I thought I would bug you here for some advice.
Use-case:
Only for motoring my boat to the next yard with better infrastructure!
What's this about?
I just noticed that my whole propulsion line id done for it, even the prop was pitted like hell (Bad connection to the anodes). Got new prop-shaft, prop, bearings etc.
But I'm a bit stingy bout the prices of new propellers here in the Netherlands (easy 20~30% up compared to other places), so I just got a "good as new" one from an outlet that is not the right one.
The original prop was 17x10RH and behaved really nice, no lugging down the engine, fair speed.
The "good as new" one I got is a 16x12R.
The question:
Is there a rule of thumb for scaling props? I know, for slow heavy vessels (mine is 12 metric tonnes @ 35ft) bigger is better. But as mentioned, I once came across such a rule stating something like "1 inch less diameter should be compensated with 2 inch more pitch".
Can anybody point me to that rule please?
I just want to see if I'm in the ballpark or just way out there.
And yes, I'm not disregarding the golden rule of "Do it right or do it twice!"
I am going to get a properly sized propeller before I go on longer trips than to the next yard.
Promise!
Best regards, FM.
Use-case:
What's this about?
The question:
Promise!
Best regards, FM.
