martinriches
I have just fitted a new shaft and cutlass bearing.I also fitted a Python drive[similar to Aquadrive] and a PSS shaft seal.I took the boat out for the first time yesterday and noticed the shaft is wobbling around quite a bit [ 4-5mm at a guess]. The shaft is 25mm dia. and the distance between the cutlass bearing and the thrust block is about 2m. I think the stuffing box must have provided some support now missing with the PSS seal. Does that sound like the problem? would a 25mm shaft unsupported for 2m be causing the problem? I would be very grateful for any answers.
Martin
Martin
