Prop Shaft Removal
Bluesbreaker
Active Member
13 Jul 2003
North Bucks.
Having removed all bolts from the coupling relatively quickly,am now having a devils job removing a pin that holds both the coupling/prop shaft together.Any Sensible advice greatly appreciated.Thinking about trying Heat?
Can't really be sure of giving helpful advice without a picture of the problem. Different brands of coupling use different methods of location - they may have a straight pin, a spirol; pin or a tapered pin. I'd suggest you visit Vyv Cox's site to have a look at various types - identifying the type might be sufficient to get help. Bear in mind though that in some installations the mechanic may have mad a modification to the standard!
http://coxengineering.sharepoint.com
Rob.
I wasn't aware of that ,however it is hard to judge,on one side of the coupling the pin is flush,whilst on the opposite side the pin is inside the coupling,ie the pin is shorter in the length than the thickness of the coupling/shaft, hope that makes sense.thanks for your suggestion,will check it out.
sounds like a taper pin, warm up the coupling use a decent quality drift with an end that is the right diameter it would be an idea to support the shaft on the underside to counter act bounce and or damage to the stern tube
but I bet it will be very difficult to remove
I'm a little reluctant to say this but when I tried to remove the coupling from the shaft it would not budge even after the pin was removed. We ended up cutting the coupling off with an angle grinder and replacing it with a split coupling so that it will be easier to remove next time.
Maybe worth saving time on the pin and split the coupling with an angle grinder.
Good luck anyway.
Good luck anyway.
That's what I would do.There's no need for pins in couplings.My Aquadrive has a split coupling tightened by a single 10mm bolt on a 25mm shaft.For bigger engines the couplings have more bolts but no pins.
