zoidberg
Among the many jobs, once I remount the prop, I'll need to replace the prop shaft nut..... but what with?
First, it's presently 3/4" Nyloc, and I have several of them, spares. Would it be adequate to stick with a fresh Nyloc nut; should I provide additional security; should I convert to a plain nut....
I can fit a tab washer, and will do so. Ought I to find a way to drill through the nut, tap it, and insert a locking grub screw? Or would application of 'The Right Grade Of Loctite' suffice?
- Red: High strength, permanent adhesion
- Select for high vibration applications where the components don’t need to be disassembled in the future.
- Green: High strength wicking, permanent adhesion
- Select for high vibration applications for preassembled fasteners that don’t need to be disassembled in the future.
- Blue: Medium strength, removable with torque
- Select to ensure components don’t come loose in the application and there is a possibility of disassembling the components in the future.
- Purple: Low strength, easily removable
- Select for non-crucial applications and if disassemble of the components in the future is a known possibility.
