Bran
It is possible to do this at home if you have a large enough table to support the length of the shaft. Make 2 vee blocks, support the shaft in the 2 vee blocks and rotate. You don’t need a dti or clock, just use some stiff wire, then use feeler gauges to check the maximum variation. You can use some wood or plastic for the vee blocks.
This gives you the idea:
