boatmike
That's most helpful. Please see my reply to fisherman. Installers are dead against any sort of flexible coupling as the claim it will allow the engine to flex more. Like I say I have to remain patient....
This is just a load of rollocks. There is no way the shaft coupling should be preventing the engine to flex. If you have over soft mounts and a hard shaft mount you will be over stressing both the back bearing of the gearbox and the shaft itself. As others have said, it is NORMAL to have a flexible coupling and it's not at all good to restrict the movement of a "soft" mounted engine by hanging it on the end of a hard mounted drive flange. I am not sure fitting a flexible coupling will solve your problem but to intimate that it will make matters worse is cretinous.
