garvellachs
Can anyone help please with renewing the bearing at the prop end of the shaft on our 1985 Maxi 100 (similar to Maxi 95)?
The "cutless" bearing is about 56 mm long and has an annular bulge on its bronze case. The bulge is held in the stern tube by a bronze ring with rubber packing, screwed tight by two stainless screws with 1/4 inch hex sockets. The internal bearing surface is a brown hard plastic-type material, with no rubber.
I haven't tried yet, but the brown bearing looks as if it would knock out of
the carrier, in which case it would be about 30mm external diameter, on a 25mm stainless shaft.
The shaft is worn at the "cutless" bearing, and the bearing is worn too. I
think both need replacing. I can have a new shaft made, but I can't find a source for the bearing yet. Any ideas?
