Pshaw
Hello,
I recently bought a 3.9hp Archimedes Penta, but have been having some issue with it. The outboard stalls at low revs, for example, and although I have cleaned the carb this still persists. This, however, is not the main issue as I can live with it quite easily.
I went to start up the outboard recently (before taking it out) but although the engine runs fine there is no thrust to the prop, and only a bit of splashing. From the last use it had been sitting in a water bin. I thought it may be gunge growing in the exhaust, so sprayed it and the water intake with compressed air, but to no avail. I then went to take the prop off (presuming it was the shear pin that had failed) but the prop seems to have rusted to the prop shaft! When I tap the back of the prop with a hammer, rather than just easing off the prop, the propshaft also starts to come out.
Am I correct in thinking it's the shear pin, and what options do I have to replace it?
Thanks,
Peter
Thanks,
Peter
