Quidi Vidi
Further to an earlier thread that I posted, we managed to beach and remove our prop the other week using our home made prop puller. I had bought a cheap replacement prop at the Solent boat jumble last year in the hope that it might fit. Our shaft is 1” dia. and the replacement prop is also 1” dia. at its widest end. However once the old prop was off we discovered that the shaft had been turned down to 3/4” at the widest end of the taper leaving a shoulder to the rest of the shaft. This meant of course that our replacement wouldn’t fit so, we cleaned off and painted the old one and the refitted it. Now to put you further in the picture we are over propped and get black muck out of the exhaust at full throttle and only about half revs when in gear. The old prop is 12x8 and using online calcs we need a 10x7, this has also been confirmed by Silette who offered to make us one but at a cost which we can’t afford.
My questions are:
Is it common to turn the shaft down to leave a shoulder, IE. Is it worth looking out for a replacement at Beaulieu?
Can I get my replacement prop sleeved to fit the shaft?
Should I get a new shaft? I really don’t want to do this due to difficulty removing old one and the costs involved
Can I get the old 12x8 altered to nearer the 10x7 I need?
Please bear in mind we don’t want to spend a lot of money and we usually do all the maintenance ourselves but I am not an engineer so I could use any advice that I can get. To that end we are quite prepared to beach and clean the existing prop every month or so to get whatever power we can.
My questions are:
