I can't get my prop nuts off, and I suspect its to do with the prop anodes needed to come off first, which I'm also unclear on how to remove, anyone familar with the below setup?
View attachment 59808View attachment 59807
Thanks!
Stilson with pipe extension took the port anode and nut off as one piece, starboard still not shifting at all.
Also now can't get the port prop off, wacked it multiple times with one of the wooden blocks they use to rest boats on, it's not moving.
Just a thought. Do both props operate in the same direction? On some twin engine installations, one prop rotates clockwise, one counter clockwise. If that is the case, then one prop nut will have normal right handed thread whilst the other will have a left hand thread, thus needing to be undone in the opposite direction. Worth looking at the props to check if this is the case.
Edit:
Looking at the pics you posted, they look as if they are a pair of left and right handed props, so they are likely to have left and right handed threads on the nuts.
Would not make any difference as the each prop rotate in different directions in forward and reverse.
Dont forget Roger is in the southern hemisphere where props, like sundials, run in the opposite direction.I'm afraid I don't understand that.
Richard
if it makes any difference, the one that's still on, is on starboard side.
The props are indeed LH and RH so might well have opposite threads on the anode/prop nut.
Richard
Don't forget Roger is in the southern hemisphere where props, like sundials, run in the opposite direction.![]()
Well the initial thought would be that with LH and RH threads the nut would tighten due to the direction of prop rotation for the forward direction of motion, but if you put the prop in reverse the direction of of rotation of the prop is now in the opposite direction which would be trying to undo the prop nut.
So it does not matter which direction the thread is cut there will always be in forward the nut may tend to tighten but the nut will tend to loosen in the reverse direction.
That's true ...... but since boats props spend 99% of the time in forward and 1% in reverse I wouldn't criticise the designer for playing the percentages if the prop nut was the only thing stopping the prop falling off.
Richard
my props are counter rotation both with the same direction thread i.e. tighten clockwise. it is the locking washer or split pin which secures it. If you have neither God help you, the seabed is littered with props![]()
You need to add to you percentage odds the with a prop in forward even without the nut the thrust is the prop would be pushing the prop onto the shaft where as in reverse the thrust of the prop is pulling the prop off the shaft so maybe the reverse is a better /safer design.
