rustybarge
Hi All,
I came across this graph by mistake; pray tell how else fellow Mobo owners would I have entered the world of 'The stuck-up & pretentious ones'... lol!
It makes interesting reading.....
>In the graph above, you can see that at 5 knots, a fixed three-blade prop with its shaft locked creates almost half as much drag as the entire hull. The drag can be halved by allowing the prop to spin, but the gearbox may suffer. By contrast, the drag of a feathering prop is negligible, and the drag of a folding prop is too small to plot on a graph of this scale.
>The hull resistance curve for the Océanis 323 was calculated for YM by the Wolfson Unit, at the University of Southampton, using data from the Delft University Systematic Series. The propeller drag curves are based on data from SSPA Maritime Consulting, using Volvo S-drives. This data were verified by YM’s on-the-water drag test.
Read more at:
http://www.yachtingmonthly.com/gear/folding-and-feathering-propeller-test-29807#esLtv8qziWRJGdSx.99
Read more at:
