tjbrace
What are the possible consequences of motoring my boat with a dezinct bronze prop.
The worn out one is a 3 blade folding prop, there is much vibration as in my original post. I won’t know if bits have fallen off until I can view the prop.Props do not normally "wear out", although folding and feathering ones can get wear in the moving parts. However if it is a fixed blade yellow metal prop there is something wrong if it is dezincifying to the point where it is losing bits and causing vibrations. Even then would likely bee the same in forward and reverse.
The vast majority of original equipment propellers and P-brackets are made from manganese bronze, a 60/40 brass with a few minor additions of other metals. Replacement fixed props are the same.There is no zinc in bronze! If there is zinc its brass, rubbish prop.
I am not surprised.The vast majority of original equipment propellers and P-brackets are made from manganese bronze, a 60/40 brass with a few minor additions of other metals. Replacement fixed props are the same.
Many after-market props are marketed as bronze, aluminium bronze or nickel-aluminium bronze but I have a collection of photos of some that are clearly suffering dezincification.
Although you may turn your nose up at them the reality is that they are fine in service. Hundreds of thousands in use and no real epidemic of early failures. folders and featherers are a different matter because they involve a mix of metals in their mechanisms so better alloys tend to be used.I am not surprised.
Even our high quality O/E prop on our island packet has a few pink spots, plus a 'comma' shaped pink bit near the root of one blade.The vast majority of original equipment propellers and P-brackets are made from manganese bronze, a 60/40 brass with a few minor additions of other metals. Replacement fixed props are the same.
You may be able to get it reconditioned. Contact here HomeThank you for all the replies.
I won’t know what is damaged until I can get to the stern gear, and the tides aren’t suitable at present.
The original fixed 2 blade prop which is ‘pink’ looks very robust whereas the newer 3blade folder is making all the noise and has done 18 seasons. I think it may be worn out and has taken my newish cutless with it.
So waiting for the tides now.
It seems that there is no recognised specification for 'manganese bronze'. This USA company https://www.wbcastings.com/non-ferrous-alloys/brass-bronze/maganese-bronze/ says:Even our high quality O/E prop on our island packet has a few pink spots, plus a 'comma' shaped pink bit near the root of one blade.
It is O/E, 16 years old now and when inspected in April during our two weeks ashore had no deteriation since I first inspected it in 2016.
The spec. says bronze, but founders use their own black art of 'when to piss in the crucible' additions of small amounts of other metals and chemicals to make casting better.
From direct experience of living next door to Walter Wilders foundry in Crowmarsh Gifford for ten years. The Foundry Foreman was a mate, one of my chums Ivor married his Daughter.
