philip_stevens
Reading a post on Sailnet.com about prop anti-fouling, one reply was the use of "Pettit Zinc Coat Barnacle Barrier", of which he said he had good results.
Does anyone know where this can be bought from in the UK - other than eBay and posted from the USA?
It sounds as though it works.
I have had varying success in either polishing or anti-fouling the prop. For a couple of years, I brought the prop home and gave it a really good shine. This lasted about half the season before it looked like a white calcium covered object. This year, I gave it a 2 coats of hard AF, and other than where it flaked off, didn't look too bad. There was some fouling that effected the revs/speed.
If this stuff is as good as the post says, and I can get some from within the UK, I will give it a go next summer season.
So, anyone come across this in the UK?
EDIT....more info on Pettit product and another product from MG Duff.
On Pettit - 93 percent pure zinc in the dried film.
"Zinc Coat Barnacle Barrier 1792 provides easy to use aerosol spray protection for bare metals including steel, stainless steel, cast iron, copper, bronze, galvanized steel, and lead. It forms an excellent bond to underwater metals and running gear, and inhibits corrosion on these surfaces. Zinc Coat Barnacle Barrier’s smooth, hard surface will self-clean in service, and can be used above or below the waterline. The dried film of Zinc Coat contains 93% pure zinc. Not for use on aluminum surfaces."
On Zingaspray - contains 92% Zinc in the dry film (pure to 99,995%). Zinga (not spray) is 96% (±1%) by weight, with a purity of 99,995% in the dry film
From www.zinga-uk.com/files/MarineTechBrief_vs3.pdf
"• In some marine environments barnacles do not like the taste of zinc and many other forms of marine life do not like adhering to the Zinga surface because of the low current passing between the zinc and the substrate."
So it looks as though I will be using Zingaspray next season. Anyone else used it??
