Graham376
Which is best on Featherstream stainless blades, Trilux 33 spray can or, Velox Plus? Can get either off the shelf here.
I have done mine with Hempel Ecopower - similar to Trilux, Did the whole prop, not just the blades. Velox is supposed to work well - it did on my Flexofold but a lot more work to apply successfully.
Neither. There is a dedicated spray primer "Prop-Primer". 4 or 5 coats. Only done last October. See thread hereDid you use the two primers or, apply direct to prop?
Prime prepared surface with Hempel's LightPrimer and apply a tiecoat of Hempel's Underwater Primer whilstthe surface is still tacky.
Velox primer and topcoat, very good results over 4 years. Taken back and completely renewed each year. On shaft and prop
They last a long time though. I am still using my original Velox top coat tin, 10 years now. Hammerite primer is very cheap: I am on my second tin of it, used for many other jobs.That's what I ended up buying today, bit pricey though at €64 for the two 250ml tins.
It does go a long way, mines done 5 yearsThat's what I ended up buying today, bit pricey though at €64 for the two 250ml tins.
