srevir
I have just acquired a 25 year old boat fitted with a 20 hp bukh engine controlled by a single Morse lever
The problem is that getting into neutral is very tricky.
My previous boat required that you press the central tit when the lever was approximately at TDC and then move the lever slightly one way or the other. This locked the tit in with no drive applied to prop. To release you moved the lever across TDC, the tit popped out and drive was restored.
On this boat this does not seem to work and I am left fiddling the lever to and fro until a 'miracle' happens.
I presume that I need to adjust the cables and or the tit but have no understanding of how the mechanical mechanism works (Being an electronics guy I have limited appreciation of such gizmos !)
There are no markings on the unit so I cannot identify it in order to try to get a manual from whoever made it
So I would welcome any suggestions for who the maker might be, what the problem might be and, best of all how to fix it.
If anyone can explain how the gizmo is supposed to work then that would be very useful too.
I have photos but cannot figure out how to insert them here (The image button asks for a URL but my photos are on a laptop not a website) so education on that point would be gratefully received.
