neiloakley
Setup: Twin rudder, single ram, twin seastar helms (in saloon and flybridge)
After my autopilot hydraulic pump motor seized, I took it off and fixed it before replacing it. This mean air got into the system so i proceeded to top up the fluid and bleed it.
When i tried to remove the filler cap on the upper helm, the fitting had seized so it had to be replaced. I used seastar part number HA5431
I then followed the instructions to bleed the lower helm first. Starting by filling the helm with oil, then connecting a filler tube to the helm so it had a constant supply of oil, and with a friend began to turn the wheel left/right opening and closing the bleed valves on the ram in order.
The instructions then go onto say repeat at the upper helm.
My problem is no matter how many litres of oil i circulate, there still seems to be air in the system. I can now turn the lower helm 2 or 3 times before there is a 'donk' and the steering starts to move. Also on full lock there isn't a hard stop like there used to be - I presume because there is air in the system that can be compressed.
Any ideas why i'm having trouble bleeding? There was no issue before I took the autopilot pump off, and i'm not leaking fluid anywhere.
