Cardo
We've been having some issues with our Beta 35 where it struggled to start. A previous thread suggested there may have been air getting into the fuel system somewhere.
So as a start, I've removed the fuel filter and replaced this. The filter was full of fuel as expected. The CAV filter appears fine. I opened the tap on the bottom and clean fuel came out.
However, I'm struggling to bleed the system. I've opened the bleed screw on top of the fuel filter and pumped away at the lever on the lift pump but no fuel is coming out at all. I've checked the hoses leading from the CAV filter to the lift pump and from there to the fuel filter and they all seem fine. Can't find any leaks and all seem tight.
It seems the lift pump isn't lifting?
Thoughts?
Thoughts?
