SolentPhill
so my second issue is there is no hot water or water coming out of the taps,
I did all the normal tried all taps on boat, and nothing comes out, yes i have water in main tank, if i turn on the cold all works fine, but as i turn it from cold and using the mixer taps make it go towards hot it slows down and stops. if i turn on the hot on any tap nothing comes out, I have gone to the water heater its a Kuuma model 41111 and on the front there is the 2 pipes from and to the engine, a blue and red plastic pipe, a pressure release valve and a tap. I thought i would work my way through and would use process of elimination to work some bits out.
I turned off the water pump disconnected the red pipe which is the hot water out to the taps, i placed one end in a bucket and turned on the water pump expecting hot water or water to come out - nothing happened.
i turned off the pump and disconnected the cold/blue pipe which is cold in, and turned the pump on and water came out.
I thought an air lock or something and opened the tap to see if any water would go in and nothing happened.
so im at a lost as to why water is not going in, does anyone have any thoughts on what this could be or what i have to do. pic below
