Printing posts
Sailfree
18 Jan 2003
Nazare Portugal
I thought it would be a good idea to print a coy of jamesJermains excellent post that included the letter to the RYA but find the RH side truncated.
Apart from cut & paste text into a word doc is there a simple way of printing complete page?
Select the text you want to print, click on file, print, selection, OK and there you have it.
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
Sorry to be dense but got same result again.
Where does "selection" come in? I click on print and it prints no way that I can see to get a "selection" command
When you hit file, print the print control window should open. Here you select your printer (if you have more than one) then in the lower left of the window you have a section headed page range - that is where you select "selection" then "apply" then "print"
Make sure you select the text you want to pring before you start clicking on "file" etc....
i have the same problem with other sites as well,you would think that by now that problem would have been fixed
I use printkey which displays the page then i either print as is or define the area to be printed.Cant understand why that works when print as dosent
