Princess V40 MkI vs Airon marine 425
Here we are .Looks a good shape nice V at the stern and sharp in the middle where the engines are sat with a fine entry up front .
Nice wide chine flats at the rear for lift so it should run flat without much tab .
deadrise has gotta near 20 , so maybe a true deep V .Nice (y)
Flip side is narrow beam on this one .But if you value seakeeping, keeping going fast when it blows up then this is better than the sterndrive VP options@ this 11/12 M point .
PYB will along with his vast experience + knowledge soon .
Thank you Porto!
I think Raffaelli's hulls were built by DellaPasqua and are consider quite rigid.
The only video I could find of a Shamal sailing, had a peculiar bouncy attitude. Check at 1:22.
Nice pics! Impressive hull!
I don't mind the narrow beam at all.
Sometimes 20cm is just enough to squeeze or not in the last available place in a Greek port - and the sun is already down!
Thank you Porto!
Just goes across the wake @1:51 . that’s the only guide . Seems to slice through FWIW .
There is a DellaPasque dealer in our marina , in the shop window as well as the typical brokerage pics he has a cross section core bores from the base of the hulls and some 30cm x 30 cm demo sections .
Its in Italian but I get the gist = solid hull bottoms .Theses are 3 cm thick solid resin .No cores , no grids , no balsa , no foam .
Other dealers of other marques put a screen and run vids of folks opening huge galley fridges :D , or using a prawn griddle :Dor place a modal in the shop window . The build side is hidden .
The coffee shop where we have breakfast is next door so I have spent hrs staring at theses x sections . :) Working out the message they are trying to say .
Coincidentally a Italian neighbour had a Della Pasqua fly 48 and traded last winter to a Raffaelli 58 HT open .
Fits the same berth .He comes across as a guy who knows his mobos onions .
