Princess headlining material
Call Pete Ward at Princess 01752 893031..........he will probably be able to point you in the right direction.
I have used Princess a couple ot times in the last month or so.........very helpful and charges are most reasonable
In my experience the number usually goes to answerphone, and it takes a while to get a return call. I have sent an e-mail enquiry to them through the web site, but I thought it was worth asking on here as well, as there are quite a few Princess owners.
I agree they're helpful enough when you talk to them, and the prices are usually reasonable, but i've said on here before that I don't think the Princess parts service is efficient enough, so I generally try and track down the OEM supplier myself.
Just a thought. I have some Fairline materials in stock in France, a couple of metres of several different headlining materials. They wont match, but if you only want to repair a patch you could, say, nick the material from your util room, use that to fix your problem, and use my stuff to redo your util room where a close-ish match would be ok. I have a staple gun on board too
Thanks John. If I can't source some before my visit next week i'll certainly have a look at the stuff you have if you don't mind, I only need small piece 600x400. I'm there Tues-Sat so may catch up on Fri eve if you're over.
Try Lang and Potter, Nick.
01752 346346
Based in Plympton.
I think they supply most of Princess' fabrics.
We bought a roll of carpet as spare.
The needed to know the hull and factory slot number and were then able to match our carpet from their records.
Might be worth a try
Mike
