Princess 50 build 2004
aisltd
14 Nov 2022
Hi all
doing some upgrades on our yacht and could do with some wiring diagrams for shore power contactor and generator contactor its a bit of a mess, have not tried princess yet thought somebody might already have them
Hurricane
11 Nov 2005
Sant Carles de la Ràpita
I'm sure our wiring will be different but maybe similar concepts
We bought our boat new but you might like to contact Princess.
They do document their builds well.
We had a shore power surge which resulted in our contactors burning out so Princess sent me the wiring diagrams for our Princess 67.
Maybe this will help but, as I say, give them a call.
From this diagram, you will see a company (T.P Electronics) on the bottom of that drawing.
It looks like they were sub contracted from Princess during our build.
Maybe worth contacting them?
Also, our shore power devices are installed in a large electric panel.
And Princess stuck the circuit diagrams to the back of that panel's door.
Have you checked?
This is a photo of our panel - the same diagram is stuck to the back of the panel door.
aisltd
14 Nov 2022
Thanks that drawing will be fine same wiring for princess 50 it had eu sockets until I changed them and has been France most of its life it also by the looks of the black over the cables had a burn out on contactors just a mess, lucky im a electrician, ours are located behind roof panel in mid cabin which is below the helm
Princess parts have been very good in supplying replacement parts cabinet catches locks etc
Also many thanks for a drawing you posted which I found for the neons for shore power 1 and 2 which I have changed all neons and resistors and again tided so where slowly getting there, I like the idea of drawings on lid
I will laminate yours and fix them on the back of the trim panel
Many Thanks Again
Hurricane
11 Nov 2005
OK
If you are going to use my circuit diagram, here is a higher resolution copy
The software on this forum always has trouble with high res photos/images.
So, I've put it on my own internet server and linked to my image.
jpg
I also have a diagram of the neon wiring - maybe too late now but maybe it will help.
Good luck with other stuff.
EDIT
For some strange reason this forum software handles the above images differently.
To download the first one, click it - then right click and Save As...
The second one seems to work by simply right clicking and Save As
As I say, the photo software on this site is a mess.
I hope the above works for you.
