double g
New Member
Hi
Has anybody resealed the cooling system on a tamd71b stb engine,there appears to be little room i'am unable to remove the inserts to replace the seals as the floor is in the way.Should i be thinking of removing the aftercoolers and heat exchangers in one lump and if so what the best way forward.what antifreeze should i be puttting back as there are so many on the market.I've been told to use the 5 yr red coolant has any body any comments that may be of help.Many Thanks in advance. Graham
