SteveGroves
New Member
I have a Princess 435 with 2 x TAMD61A 306 hp engines, and have recently developed a really difficult fault to isolate, the port engine starts easily after time on shorepower whilst the charging system is on, and will run happily for a days cruising, however, once the engine is shut down, it will not start from either upper or lower helm position until the boat has been back on the battery charger for a while. The engine then starts on the key.
The starboard engine is fine and starts every time, but the only way to start the port engine is by shorting the activator pin on the solenoid to the HT lead, the engine then starts easily.
I've put new engine batteries in, which are wired in series, so both batteries provide the cranking power to start 1st one engine, then the 2nd engine, checked cabling condition and earth points, put a new starter motor on the engine, and even swapped ignition switches on the lower helm, I've tried starting the starboard engine first, waiting till the charge come up to 13 volts, then tried starting the port engine, but cannot isolate the fault.
I know its something to do with charging, but the starboard engine always starts, and there,s power in the batteries to start the port engine as this fires up when I short out the solenoid.
Any idea's?
Steve
Any idea's?
Steve
