KREW2
My mild steel fuel tank has been taken out cleaned. I have wire brushed the outside and given it two coats of primocon. It looks okay as it is, so do I need to top coat it?
It is intended to be used as an underwater primer:My mild steel fuel tank has been taken out cleaned. I have wire brushed the outside and given it two coats of primocon. It looks okay as it is, so do I need to top coat it?
I wouldn't bother putting a topcoat on.
A quick drying, general purpose below waterline primer which has been formulated for use on metal keels and hulls prior to antifouling. It is however also suitable for use as a barrier/sealer coat between unknown or incompatible antifoulings.
I just had a bit left at the bottom of a tin so wapped a couple of coats on the tank, can't see it doing any harm, I hope. Just wondering wether it needs a topcoat to protect it.
Primocon will work perfectly well as a primer on your tank but it would be better if finished with a topcoat. It does not have good exposure properties, especially UV. UV probably isn't too much of a problem but it will perform better with a finish.
It is sold as an underwater anticorrosive primer but that doesn't mean it is not suitable above water. Usually the reverse is the case - primers designed for above water use cannot be used immersed.
I must take issue with the comment about red oxide. Red oxide primers are about the lowest grade of anticorrosive money can buy. Technology has moved on massively since red oxide had any credibility and there are many better options.
Primocon is a very good primer. Using thinners no. 3, as opposed to no 1, it is very durable when dry, and will resist oils etc in the short term. It has high solids, and will form a good barrier from air and moisture.
Painting the rusty bits in some way before painting with something like Fertan or Vactan would have been best, but two good coats of Primocon will last far longer than Hammer****e or other DIY 'metal paints'.
If you want to overcoat it I would use a single pack polyurethene paint, and do it in white so you can see where the rust reforms, and to lighten up your engine room.
