lindsay
I have a Volvo 2002 diesel in my 29 foot sailboat, with the fuel line going from the tank to a primary filter/water separator (glass type) then on to the engine filter. Changing the engine filter and subsequent purging is a breeze. Purging after replacing the primary filter is anything but ie filling it up in the first place, juggling with difficult and uncomfortable access, a rheumatic thumb, a stiff neck and those three pesky gaskets of different circumferences in the filter itself.
A solution is, apparently, to change the filter system. A much cheaper solution I understand, is to fit an outboard type purging bulb in the fuel line, particularly to get the primary filter filled to the top where it can be purged easily. Since this little potential marvel costs anything from GBP7 to 14, this would be my choice.
My question: which side of the primary filter should it be installed, between the tank and the primary, or between the primary and the engine filter?
