Prices for replacing standing rigging
Aeolus
3 Aug 2004
Sussex
I've just been quoted ~£140 plus VAT per shroud/forestay/backstay for new standing rigging. This excludes fitting.
Does that sound expensive? It's for a 29 foot masthead sloop.
Depends on the fittings you have specified on the ends, and whether you want new bottlescrews. The rigging wire itself is quite cheap (about £1 a metre for 4mm), but a swaged terminal would cost around £16 each end - this according to the last bill I had from Spencers Rigging in February.
Just to clarify - that's £140 plus VAT for each shroud, not including new bottlescrews and not including fitting.
If swaged terminals are £16 each and 6mm wire is around £3 per metre, then a 12 metre long shroud should cost £16 x 2 + £3 x 12 which works out at £68. I'm being charged double that. Or is my calculation flawed?
I took all mine off(mast already down) and took it along to a local firm in Sittingbourne Kent. All done with new bottle screws,swaged terminals,and they even supplied the split-pins. under £300 the lot for 27'masthead rig
Sounds expensive. Most riggers now use bottlescrews that have one end that swages on to the wire, so each shroud has one swage and one bottlescrew included.
Try a quote from Jimmy Green. I was very surprised at his prices when I re-rigged last October. Service and supply time was excellent too.
PeeGee, what firm was that in Sittingbourne, please?
TS Rigging in Maldon. 26ft Centaur, 6 wires and end fittings in 5 and 6mm £3-400. Sounds like your quote is on the expensive side.
Bought a complete set of standing rigging this last winter for a 32' Rival. Including two insulators for the backstay (which were £273 fitted into the stay), the total was £902. This includes forestay @8mm, backstay @7mm, 2 sidestays @7mm and 4 shrouds @6mm all with swaged eyes both ends except the forestay one end only. (furler). Old stays collected, (to verify sizes) new ones and old ones delivered back.
I thought that good value.
