ShipsWoofy
Out of curiosity, how long must you run the engine to get enough hot water for a shower say?
I have actually considered dumping my airtonic and fitting one the hydro types with a radiator circuit around the boat too. Trouble is, this means a lot of pipework and serious changes to the fresh water system, including a long run from the tank to the heater and back to the heads. But this would be a similar problem for engine heated water... How much water do you need to run off before hot starts coming through..
See, water is precious on a small boat, and really, we all sail small boats.
I am also guessing you need copper pipe to deal with the heat, this would all add to weight on board our tonka sized cat, thus it will probably remain a 'pipe dream' <pun intended> So I should stick to the 'DogWatch KISS hot water system™' I think.
