sidon
I have recently noticed that when running under engine my Jeanneau SO 37 dumps an alarming amount of hot water in the bilge from the cleghorn waring pressure release valve, this does not happen when using the immersion heater on shorepower. This point me to the conclusion that the water coming via the engine is hotter than the release valve is set at. On further enquiries I have found out that nearly all the SO37's sold in our area do the same. On confronting the dealer the explanation was, that due to global warming the sea temperature in the U.K had rissen by approx 1.5 degrees causing this problem. Also because my boat was 16months old she was out of warranty, but the dealer would supply a new valve at trade cost. What worries me is why is this valve going to be any better than the old one, as it is exactly the same valve. I would be gratefull for any advice on how to rectify this problem ie which valve to use etc.
P.s. If the dealers theory is right I bet there is no such thing as a SO37 in the med with hot water! due to the higher sea temperature. Thanks in anticipation.
