Pressure switch on a Jabsco pressure wash pump?
Ian_Edwards
9 Feb 2002
Aberdeen Scotland
The pressure switch has failed on my deck wash pump.
I can't find a spare anywhere online.
Has anyone replaced the pressure switch?
Where can I find a spare?
I can only find new pumps, but pump works ok when I bypass the pressure switch.
It's a 12volt impeller pump, and the pressure switch is a small blue box on the end of the motor.
I replaced the entire pump earlier this year. Let me have a look. I thought it was just clogged and was planning to try to clean it up as a spare but I haven't done anything about that yet.
Found it quicker than I thought. 2.9GPM pump. Pressure switch is a sort of flattened blue hexagon. Appears to be held on by a single screw. Does that sound like it?
Find your pump on the Jabsco shop website scroll down and you should see a parts diagram and list
http://www.jabscoshop.com/marine/pumps/
Use the spare parts wizard to directly locate it from the model number
If all else fails you should be able to order directly from Jabsco
