Pressure gauge
elliottwb
10 Jun 2020
Thanks for my welcome to the forum.
I have an XM 260 inflatable, inflated pressure is 0.2 bar?…data plate unclear.
Is there a pressure gauge available to fit the valve ??
best.
You can get pressure gauges for inflatables, but they're quite expensive. For most people, just pumping up until the tubes feel solid is sufficient. Most ordinary foot pumps have a max pressure of around 0.3bar, so you're not going to explode the dinghy! (The double chamber pumps used for inflating aerodeck floors can usually produce up to 1 bar on the high pressure setting.)
pvb,
thanks so much for this. I have a foot pump so 0.3 bar is about right.
I also have a double chamber pump with pressure gauges which I use on my blow up kayak, it has Boston valves.
