steveej
Hope you all aren't in the pub......
I am in the process of prepping the boat for unstepping the mast.
I have 5 wires coming down through the deck - 2 x electrical wires for anchor light and steaming light, TV arial, VHF arial and Raymarine Wind instrument.
The wires for the light should be easy to remove, just cut off the crimps and pull them through the glands. The TV looks like it carries on through the head lining panels and goes direct to the TV - is it safe to cut this and put an F connector on it? or will it mess up the signal. Would rather not disturb the headlining panels.
The old coupling on the VHF is corroded so want to change this - can I use another F connector or is there a special connector that needs to be used.
The Raymarine wind instrument seems to be a wire going into a black box is this easy enough to remove? Hanevnt tried yet.
Finally - any tips for sealing everything up seen as it may be a couple of weeks before it goes back up.
Cheers
Steve
Cheers
Steve
